interchangeable lower units??
billybaja
Hi, I was wondering if a lower unit from a 1982 140hp johnson 20" shaft or leg would be useable on a 1984? (I think) johnson 115 hp also 20" shaft or leg? I have already swaped the tilt over to the 115 no problems just checking the gear fluid after running the boat last night and I def. have water in the oil.. I had just put fresh oil in the 115 and it turned kinda of milky.. I know the 140 lower unit is good the powerhead went bad just looking to get one out of twoalso have new waterpump and gear oil in the 140 unit Thanks ,Bill
patrick4266
Re: interchangeable lower units??
Horsepower--------------------------------------Years that interchange
40/48/50/55/60..... (small diameter housing)..................1976-1988
40/48/50................................................ .................1989-1992
40/48/50................................................ .................1993-2005
70/75............................(20 inch shaft)......................1978-late 1981
60/65/70/75................................................ .............1982-1988
50/60/70................................................ ..................1989-2001
85-140.............(crossflow 13 spline prop shaft).............1978-1991
88-140.............(crossflow 13 spline prop shaft)..............1992-1998
120-140 Looper V-4... (15 spline prop shaft)...................1985-1991
75-115 60 degree........(bat wing unit 13 spline)...............1995-2006
150-235 & 2.6.................(crossflow V-6)......................1979-1991
185-225.........................(Looper V-6).........................1986-1991
185-225....................(Looper V-6 & Ficht)....................1991-2005
150-250.......................( Magnum Series).....................2002-2007
150-250........................(Lighting Series)......................1997-2001
patrick4266
According to the chart by "fatzbullet" it will.
billybaja
Wow Thanks, fast and good info... gonna see if I can put that chart in my files, real handy to have that information ...Thanks again ,Bill
