yonipainting
- Joined
- May 18, 2008
- 86
I have searched lots of discussions but did not find a problem like this.
I have 77 2.3l OMC and here is what happens.
Starts like a charm, idles good, responds to accelerator in idle - no problem-
When I put in in gear (forward or reverse), it goes only to about 800 to 900RPM and then chokes down if i press accelerator more. It backfires and dies. I can not push accelerator fast to "pass" the point - it dies also.
Nevertheless, if I just keep it running (in gear, in water)) at 800-900 RPM for about 5 min it suddenly goes up slowly and then I do not have any more problems for as long as I do not turn the engine off - then the story goes from the beginning!
One more thing, the engine does not warm up (stays along 120 even if I run it at 3000 RPM in idle for couple of minutes)) untill it goes over those 1000 RPM.
