interference
springhead
Hi people, i have a 2000 silverado.
there is a high pitch sound, some kind of interference that is getting worse by the week. i think its from the stereo speakers,
the weird thing is it happens even with the stereo off.
anyhelp would be great. Thank David
jimr
Re: interference
does it change with engine rpm? if so possible alternator diodes going out.
Bob_VT
Re: interference
I have seen that happen when a Body Control Module goes bad. It's electrical related. Does your radio turn off when you exit with the ignition off? Any other strange things happen? If it is getting worse I would check with a GM Tech.... There are probably a few on iboats.
springhead
Re: interference
it doesnt change with the rpms.
my stereo goes off when i open the door with the ignition off.
xtraham
Re: interference
probaly the fuel pump getting ready to crap out if it doesn't change with engine rpm's
ob
Re: interference
Do you just think or know that this sound is coming from the stereo speakers? Did you put your ear to the speakers to verify?
springhead
Re: interference
i actually dont know for sure if its the speakers.
ill let someome drive and ill check.
i do know the noise is coming from inside the truck.
