I am redoing the interior of my 25-year-old 18.5-foot Bayliner Capri. So what wood should I use?
I have done some research and many say epoxy coated plywood. Problem there is when I run a bunch of staples in; I give water many tiny holes to enter. Also epoxy coating plywood is a fair amount of work. The side panels appear to be painted plywood and lasted 25 years and are not that bad, and could possibly be reused. The seat bottoms look to be the same untreated plywood and are rotted.
I understand there is plastic wood, however it is a bit out of my price range.
I am leaning towards using green treated plywood, as it would not loose its rot resistance when staples were put into it, and it would be better than untreated.
