Re: Interlux 404 Primer advice
Assuming you used a roller to apply it, it sounds to me like you may have missed a step. Primecoat will go on pimpled or "stippled" with a roller alone. That is why it is recommended to apply an even coat with a thin nap foam roller and then immediately "tip" it with a badger or china bristle brush as you apply it. This flattens the stippling and evens out the coat even further. If you rolled it on and left it to dry, it dried with the stipples.
No major problem though. Sand it, sand it, and sand it some more until it is smoothed out and roll/tip another coat. Then sand it, sand it, sand it, sand it........and when you have had enough sanding, sand some more. (not all the way through, obviously)
