interlux traditional marine enamel ?
canman
hi everyone . i picked up a paint chart at the paint store and it showed this paint i was wondering if anybody had tried this paint ? it says to apply the paint with a sponge roller . i like the gunmetal grey colour . the boat is a 1986 l6 foot larson zensa bowrider with a 140 johnson on it . thankyou .
TheWoodCrafter
Re: interlux traditional marine enamel ?
Interlux is a big marine paint manufacturer.
What line are you thinking of using
Brightside or Perfect?
Britghtside is a 1 part poly.
Perfect is a 2 part poly (toxic when spraying)
Roll and tip is a good option for non-spray application DIYSers.
canman
on the can it just saya traditional alkyd based marine enamel , bright, high gloss finish .
tallcanadian
i did my boat with interlux brightsides using a sponge roller. exception is i did the roll and tip method. turned out good. but remember, your prep will determine how good your paint job turns out. use interlux primer and sand to a smooth finish. the use the roll and tip. your paint will smooth out nicely.
seven up
I've tried "Bluewater marine paints" but not at Interlux prices.
Alkyd enamel is like porch and garage floor paint if I'm not mistaken.
LeftFeild
Well Brightsides does leave a very good finish and is very durable, Perfection is by far more durable and well worth the money,and if done right it will rival any professional job.
Woodnaut
I used Interlux Brightside on the hull above the waterline, on the deck and throughout inside. I turned my garage into a paint booth (took a week) and then sprayed everything. After several years the finish still looks great and is very durable. Preparation, however, took a while. Sanding, primer, sanding, primer, sanding, paint, sanding, paint. I think the finishing took more effort than building the boat, but now I'm really glad I did it. Year after year, this same finish has held up well and really looks great.
