Intermediate Shift Shaft sitting to low to shift.
dbhickey
Hi,
My outdrive is very difficult to get into gear. Upon inspection I noticed that the itermediate shift shaft is bearly seated in the shift shaft on the bell houseing. I have read in the forums that the intermediate shift shaft is held at the approriate height by a washer on the lower shift shaft. When I review the parts diagram i see a cotter pin and washer. If these were missing from the intermediate shaft would it fall a little lower?? If that is the case I think inserting a cotter pin should do the job.
Thanks
Re: Intermediate Shift Shaft sitting to low to shift.
Hi,
Thanks
Ayuh,... It's usually the washer that's missin', causin' the problem..
But, Ya, yer headed the right way....;)
dbhickey
Thanks,
Just to clarify. What is the purpose of the cotter pin. Is it there to keep the shaft up. I would rather replace the cotter pin that remove the lower unit to replace the washer.
Don S
The cotter pin has nothing to do with holding the shift shaft up, that is what the washer does. The cotter pin holds a different washer in place and prevents the shift shaft from coming out of the hole.
dbhickey
Thanks,
I gues i will have to remove the lower unit and replace the washer.
Don S
You would have to remove the lower to access the cotter pin too.
dbhickey
I understand now. I was hoping that the washer and cotter pin were on the bell houseing side and i could gain acess from outside.
