Hello all<br /><br />I have a '76 20hp Johnson and I was out on the water yesterday when my outboard started acting up.<br /><br />I would attempt to put it into forward (or reverse) and the prop would not engage. The little nub that covers the bolt that holds the prop on would spin, but the prop itself would not turn.<br /><br />I tried shifting at higher and lower RPMs, but that did not help. I kept on trying to shift from neutral to forward and finally after about 10 or so tries it engaged the prop and I made my way home. This happened a couple of times as I was travelling through a lake that was choked up with weeds so I had to stop periodically and clear the weeds. When my motor would stall out during that time, I had issues with getting it to re-engage.<br /><br />Does this sound like a spun prop? I have done a search on this forum and that is what I came up with, but wanted to ask this specific question just in case any other suggestions came up.<br /><br />Thanks
