little mfg
- Joined
- Jun 27, 2016
- 72
Hi everyone. I've been working on this motor all summer long trying to get it to run at full throttle. So far, I've rebuilt the fuel pump--no change. I've replaced the hoses/clamps and fuel line/primer bulb and gas tank--no change. Lastly, I pulled the bottom carb, cleaned it and reinstalled it--no change. I've had some minor events of brief success the last couple of sea trials, using the towel over the carb throats to see if any junk would spew out. The bottom carb was, I thought, the culprit. I especially suspected it because it had the least amount of vacuum pull on it when covered--hardly any. Now it seems on par with the other two carbs. The gaskets looked OK. The needle valve had just a slight partial score, but not enough IMO to cause a major problem. The jets were all clear. The float is level. It does have a surface crack but I floated it in gas overnight and no fuel inside while shaking it.
Today it ran at full throttle for about a minute when I realized the choke butterflies were hanging partially closed. I manually open the with the choke knob full in at the motor and vroom, off she went. Stopped the motor, put the hood on it and it reverted right back to 8mph top speed. It is also guzzling a ton of gas! Oh yeah, I also did the seafoam in gas treatment early in the summer. What should I do next? Any suggestions would be greatly appreciated. Thanks in advance! Doug in Ohio (Lake Erie, central basin).
