1995 88SPL Evinrude
I've been having a problem with my engine after idling/low speed cruising for a bit. It seems to 'load up', running a little rough. It almost seemed as if it wasn't getting enough fuel at idle, or if the plugs were getting fouled up and firing incorrectly.
I pulled the carbs off, cleaned and 'rebuilt' them...so they are as good as new. They were pretty clean as it was, should've been fine without pulling them off but it didn't hurt anything either.
I reinstalled the carbs yesterday and cranked it up. On the hose, the engine will run good for a few minutes. I usually set it at a high idle or so, 12-1500 RPMS. After it warmed up, it started loading and missing again, dropping the RPM's down into the 700 range and trying to die. I guess the carbs weren't the problem.
So, I waited until dark, and started it back up. Let it warm up, and had the same problem. With the cowling off, and all lights off around me, I could see arcing around the top right cylinder's spark plug (cyl 2?). The spark was coming from the brass 'nut' area of the spark plug, and jumping towards the spark plug boot. There was also some arcing in the coil area near wear the spark plug wire plugs into the coil.
I also noticed the other three spark plugs would almost 'glow' blue when they were hitting...but I assumed I was just seeing the spark through the ceramic...basically the ceramic would very faintly light up...but now sparking on the outside.
Does this sound like a coil, plug, or plug wire problem?
What is the best method to go about testing this?
Plug wires are only about 2 yrs old, coils are original, and plugs were new midway through last season.
Thanks
Shawn
(PS: No manual yet...waiting on it, eager to get this thing on the water).
Thanks
Shawn
