imported_eric
- Joined
- Jul 22, 2006
- 11
Hi guys. Thanks for the help in the past. I still seem to be having intermittent power problems. I have a 94 115. Some times, it will pull an adult skier out of the water like nothing, other times it can hardly get a kid out of the water on 2skies. I am getting frustrated because there were issues with the fuel pump. That seemed to fix it at first, but then the problem returned. there was some evidence that the one cylinder was a little scoured from heat, even though the warning horn did not come on, and they were tested and they work. The compression is all between 105 and 115. All the wiring, power pack and stator have been tested and working fine. could it be a faulty fuel line? The vro has been taken off. It just seems as though sometimes it jumps out of the hole, and other times it just dogs. Help!
