I have a 1974 135hp Evinrude. v4
I have been having hard starting issues, and idle issues. WOT there are no problems. While trying to set the timing today I noticed that my timing light would only work intermittently. Well turns out it's because my number one cylinder wasn't firing. I did a spark gap test and found cylinders 2 and 3 work well all the time. But 1 and 4 sometimes work and other times don't fire at all, When they are firing (i can tell by seeing the spark in the gap tester) the engine runs great.
I have a service manual but all their test require a neon spark tester..... whatever that is. Seems odd to me that the problem is on separate banks of the engine.
I also switched spark plugs and still had problems with the same cylinders.
Anybody have any ideas?
flywheel magnet? Sensor Gaps?
Thanks!
Thanks!
