Intermittent Starting Problem 2002 Four Winns 260 Horizon
BobG133
I have this strange issue where sometimes I turn the key to start and nothing more than the beeping happens. I try it several times and nothing. Then all of a sudden it works? I think just before it works I hear a motor running in the engine compartment, like a small electric motor, or something electronic buzzing.
Once it starts for the day, it will keep starting all day usually. I may go try it the next day or 3 days later and it's fine. The day after that it doesn't start again.
Very often I have to hold the key in the on position for like 5-6 seconds then I get the starter turning and it fires right up. It has me baffled, is there an electronic module that has to fire up before it will start?
Ayuh,.... Welcome Aboard,....Startin' at the battery, remove, 'n clean to shiny metal Clean, All the connections, both cables, both ends,....
