hoowahfun
- Joined
- Sep 1, 2016
- 186
Engine is a 1987 3.0, S/N B515218.
Engine is currently not running, and wanted to do a compression test as a start to some diagnostics I want to do on the overall engine. Engine was seized when I got it, but freed it up after soaking the pistons for a few days and changed the oil.
Engine dose not run so test was done on a cold engine. Compression test went as follows:
1) Removed plugs and grounded the wire coming from the coil.
2) Throttle at neutral position. Would not crank at forward position so I kept it at neutral (honestly I don't see why throttle position has an effect on the test...maybe someone knows?).
3) Went front to back with the tester and cranked it over a few times (4-6) until the needle on the gauge didn't move. Dry test results:
1-160
2-50
3-90
4-130
4) Tried to isolate cylinder #2 to see if the low pressure could be from a blown head gasket. Dry test with plug in 3: 50 psi (no change). Dry test with plug in 3 & 4: 50 psi (no change).
5) Tried to isolate cylinder #3. Dry test with plug in 2 & 4: 90 psi (no change).
6) At this point I thought either cracked block/head, stuck valve, or stuck rings. So I started with a wet test. Pumped in 3 squirts of oil from my oil can into cylinders 2 and 3. Put all the plugs back in, cranked it over a few times. Removed the plugs then tested 2 and 3. Wet test results as follows:
2-80
3-125
I was encouraged at this point that it could possibly be stuck rings causing low compression, thought number 2 concerns me a lot. Still could be other issues, but other tests will hopefully reveal that. Service manual calls for 140 psi as normal compression. I went back and also did another test on #1 since I thought 160 was pretty high. Final dry test on #1 gave me 120 psi, but my key almost broke off in the ignition so I had to stop the test after a couple of revolutions. This number makes more sense to me given the age of the motor. I'm going to try to have a couple of other keys made today and try to repeat the test this weekend.
Initial thoughts???
Thanks!
1-160
2-50
3-90
4-130
2-80
3-125
Initial thoughts???
Thanks!
