Inverted steering
Formula330
My boat came back from mechanic (since out of business) and it steers backwards (steer right it goes left, and vice versa)! Twin inboard outboard bravos. I've been reading posts but need help. Any advice on how I can fix?
Davetowz
If it is a rack system, the rack is mounted upside down at the helm. BTDT. Need more info. What steering system do you have.
jimmbo
What was the boat at the "Mechanic's" for?
So when you turn the Wheel to Port, does the outdrive pivot so the prop end goes to Port or to Starboard?
Formula330
It was in for one Engine work.
I'll check today which way outdrive pivots when I turn wheel to port. Stay tuned and thank you
Unbolt the rack from the helm
Unbolt the helm and rotate it 180
Reinstall helm
Bolt rack back on
