ipc for 150 ficht fuel injectors
toddr5516
I'm wanting to get an illistrated part breakdown of a fuel injector for 1999 evenrude 150 ficht motor , can anyone show me a diagram of this injector?
seahorse5
Re: ipc for 150 ficht fuel injectors
There is no parts breakdown of the injector itself, the parts are all specially fitted and calibrated. The injector assembly even comes with a software disk to tell the computer the flow characteristics. The injectors are repairable by DFI Technologies in AL.
For a parts breakdown of the outboard, go to the Evinrude website and click on ENGINE DIAGRAMS
toddr5516
well i took on a project to get this motor to run and complete clean of the fuel system everytime i got to another point i'd try to crank the motor .
i eventually got it down to the injectors themselves and took them apart and cleaned on re-assembly tore one of the o-rings in the injector and had to run around to find this specific size o-ring.
could not locate but did use a substitute in its place.
put motor back together and it runs
later found out i saved thousands of dollars on replacement of injectors.
tim1198
How did you take it apart? I'd like to be able to do the same with my bad injector ($525 for a new one).
Thanks,
Tim
hemijosh426
Will the software diagnostic tool calibrate the injectors? I bought a motor that had a bad injector, but the motor still doesnt run good with a good injector.
