IPS hull on an SSV14
Hobocreek
Can anyone tell me the advantages of the IPS hull on the SSV models. I'm trying to compare with the WC14 and would like some reassurance that the extra $s are worth it.
Navy Jr.
Re: IPS hull on an SSV14
My understanding regarding IPS and IPS2 hull designs is that they provide a more stable and drier ride when the boat is at speed. They also bite much better in turns, have faster hole shots and get up on plane faster.
Lund really offers a lot of models and there is some real overlap between them...I keep expecting that some day they will simplify their lineup but it still hasn't happened...
The SSV line is really their "heavy duty" basic fishing boat while the WC is a little lighter, a little smaller, and a bit less expensive. Over the last 10 years they have continued to beef up the WC's with heavier construction to the point were they are now the basic equal to the S-series from a few years ago (which were replaced by the SV's, then the SSV's). Even the older Lakers and Rebels used that hull before the IPS movement.
Going from memory, the fundamental differences between the SSV-14 and the WC-14:
Horsepower rating: 35 SSV, 25 WC
Splash well: Included on SSV, not available on WC.
Seating: the two rear seats are walk thru on the SSV while only the rear is split on the WC. I think there is more storage room under/behind the rear seats for gas tanks and batteries on the SSV (you can get 2-6 gallon cans and a battery back there).
The SSV is about 5" deeper at the bow and along the sides compared to the WC.
Now, the hull:
The IPS hull is a true Deep-V design but incorporates flared chines and a flat spot on the bottom of the hull at the transom to facilitate better flow to the motor. The full V-shape means that the boat will be able to cut heavy chop and waves better. The flared chines help to provide lift to enable a reasonable sized motor to still plane it out with a decent load. They are trying to strike a compromise b/t smooth running in waves and max top speed in calm conditions.
The hull on the WC is what Lund calls a "Traditional" hull. Some might call it a semi-Vee while others might call it a modified V. It is NOT a deep-V where the V shape extends from stem to stern. Instead, the V starts and the bow and gradually transitions to a flat hull bottom at the transom. Such hulls plane easily and give you a flatter floor inside the boat but give up a little bit when it comes to running balls out in heavy seas. In some case you might find yourself backing off the throttle to dip the bow back down a little to cut the waves.
We used to run a 15 hp motor on an old S-14 (dead ringer for the new WC-14) with 2 adults and 2 young kids and it planed well enough for our purposes. The cost delta between the two series of boats is pretty big so if you typically venture onto rough water (big northern lakes) you would be wise to pop for the SSV. If you are more of a fair weather fisherman or don't mind taking it easy in rough weather the WC would be entirely adequate and perfectly safe.
That said, the older WC's (say 10 years ago) were quite a bit lighter so if you buy used make sure you know what you're getting into. Now even the aluminum thickness is the same (from memory) as the premium SSV series.
If it was my money, I'd go for the SSV for a few reasons...The splash well is a big one to me since I am a backtroller and it keeps you from having to bail as often if you're taking water over the stern (plus, it is a handy junk storage tray for marker buoys, sinker containers, etc). And, the extra depth in the bow and sides can make the difference between having a wet butt and staying dry on a windy day.
and - if your budget and needs allow - the 16' version will be a little more roomy (between the seats) and will be more attractive to future buyers when you go to sell.
Finally, the SSV will hold its value better amoung people "in the know" on Lunds versus the WC or A series since it is a "premium" type of boat.
With either boat, opt for the 20" transom. And get a 25 hp motor if your budget and situation allow. Even on a 16 footer a 25 is perfect for these simple boats.
If you were to have a drag race of two identically equipped boats - one an SSV, the other a WC - I'd bet on the WC as being a touch quicker and faster since it is not a true deep V. The SSV would shine in rough conditions and might be a touch more stable at rest since it is wider in the stern at the bottom due to those chines. Give and take.
Whew, long winded...
Your mileage may vary.
Best of luck!
Steve
Coastalguy
Steve,
What a wealth of info you provide on these basic Lund boats. I bought a new 1985 Lund C-14 with a 15hp Evinrude had it for 10 years and even took it 7 miles off the Maine coast to Jewell island with little problem. I now own a 97 SV-14 also bought new with a 20" transom and a 25 hp Johnson, it does
25 mph at sea level with 2 aboard. In addition to providing a stable fishing platform It has been good on larger bodies of water and I even took it on a 60 mile round trip on the Ohio river in KY.
I'm planning on going a bit bigger this year looks like an SSV-16 powered
by a 30Hp Evinrude e-Tech. Living in Denver I think the 30 is a good Idea with the altitude. Just to pick your brain a little. Some say the wheel steered versions of the SSV are a bit faster with the same engine due to weight distribution, Myself I think with one adult in the first big seat up front
and me back at the tiller it comes out about the same. With a tiller you
get more precise steering, more usable space in the boat and it's less costly.
Ok As long as you don't have to sacrifice much speed in calm water? Also wondering if with this new IPS hull design if it's really a good idea to raise
the engine about an inch above the transom for best performance. On the
older small Lunds you had to raise the engine a bit to get the anti cav plate
even with the boats bottom. No live well on these SSV boats but a cooler
seems to work ok for short trips and makes nice ballast up front for 1 person
operation.
Planning on buying a house next year so I better get this new boat purchased first or it might never happen, don't even guess which is more on my mind now!
Thank you and Happy cruising/fishing 2010 COASTAL GUY
Happy cruising/fishing this year
Huron Angler
Now I agree with that statement:D I employed the same strategy when I got my '79 SS. Gotta get the boat before the mortgage kicks in;)
I would opt for the SSV if you can swing it due to the higher sides and splashwell. A splashwell is a truly nice thing to have even if you only truly need it once or twice during the entire time you own the boat.
Both great boats though!
SeaNymph Man
Now, the hull:
Best of luck!
Steve
You're a treasure chest of information on the basic Lund boats,...that was very interesting to read. Due to tighter budget,I have gone with the A-14
which has the "traditional" hull,or "classic v" as Lund calls it. I would like to have been able to go with the WC,but my budget just would not allow it at this time. The A-14 is rated for 15 HP maximum,so mine is having a 15 HP Mercury four stroke( a Tohatsu with Mercury badging)for power. Had my budget allowed an SSV series boat,I'd have gone with a 16 ft. model with a 40 HP Mercury four stroke for power.
I like the tiller steer boats as they are more affordable and have more precise steering. I also like the simplicity of a tiller steer motor,...no steering cables
or throttle cables to worry about breaking or maintaining. Back to the boats,..
the A-14 is actually perfect for me in the sense that I fish small to moderate
size lakes,and it is far easier for me to move around on dry land.
In regards to the IPS hulls,...they do provide a more stable ride and allow the boat to be more stable at rest as well. I would pay a little more even if they would provide the A-14 with an IPS hull,and add the little 'splash well'.
Hobocreek
I ended up going with the WC 14. The cost difference was just too much. I had a chance to fish from a WC 14 dlx and a two year old SSV 14 last summer before I decided to buy. In calm water to moderate chop the two hulls handled and behaved very similarly. The SSV did give the impression of being a sturdier hull and seemed bigger even though it's a few inches shorter. If I could have found a used SSV around my area I would have gone for it and the new prices on the dealerships within a few hours of my place were quoting me a $1000 - $1200 difference between the two. Even though I had to settle for my #2 choice, after fishing a few times, I'm really happy with it.
