guy74
- Joined
- Jul 12, 2007
- 794
I've finally torn into my 1989 100XP Evinrude, E100STLCEM, looking for why it doesn't idle right. #4 is running lean at idle, spits once in a while. I can cover the idle air bleed on #4 with my finger and the motor idles perfect. I've rebuilt both carbs, they had nothing wrong with them, perfectly clean. The only thing I've found is a leaking recirculation check-valve, will flow in both directions, on the offending cylinder. The other three check-valves work fine. I visually inspected the reeds though the carb mounting holes with a borescope, nothing looks out of place. My guess is that the check-valve was leaking air back into #4 and leaning out the idle mixture, am I on the right track? BTW compression is 120-122 across all cylinders, with good spark.
