IRRATIC OR NO SHIFT OMC COBRA
jimmyvan
'90 VIP WITH 2.3L FORD & OMC COBRA STERNDRIVE IS INCONSISTANT WITH SHIFTING - IS THIS PROBABLY A TRANSOM SHIFT CABLE? IS THIS COMMON? AND DO THEY HAVE 100 DIFFERENT CABLES OR ONE SPECIFIC TO REPLACE IT WITH IF THAT IS THE PROBLEM?
clanton
Re: IRRATIC OR NO SHIFT OMC COBRA
Do you mean thet it jumps out of gear, or engine stalls when shifting?
seahorse5
All Cobra I/O's use the same shift cable.<br /><br />Describe the shifting problems.
jimmyvan
thank you everyone. i found the transom cable pulled out of brass fitting at the lower unit. with the input, i picked up a cable on the way to the lake and fixed it the same day! thanks again
