Irratic timming
wire knot
After adding a rebuilt carb, setting the dwell.
The timming is jumping, maybe 2 deg., from
the setting mark.
Where is the most likley problem?
The chain cover does not have a timming
mark that sticks out, it is just a slash molded into the cover. Anyone familiar w/these.
The motor is a OMC '75 -350/4bbl
Thanks
WK
Silvertip
Re: Irratic timming
Worn upper distributor shaft bushing or stretched timing chain. My guess is distributor shaft bushing. Hook up a dwell meter and watch the needle while blipping the throttle. If dwell jumps around, its the distributor. I've also seen brand new points that have a loose contact. The engine runs fine at idle but the contact bounces at higher rpm again causing dwell and timing to jump around.
wire knot
Re: Irratic timming
Thanks silvertip,
The dwell does not move, at all.
through all RPM's, ......no load , anyway.
Coors
Re: Irratic timming
hook a vacuum gauge up, and check that; if vacuum is good, may be chain
bruceb58
Re: Irratic timming
Coors,
How is vacuum going to affect timing?
Don S
Re: Irratic timming
What year is your engine. The older ones did not have a way to have a "Molded in" timing marked. They were stamped sheet metal with a welded on timing mark.
As far as your timing jumping, they are never 100% solid. A little crossfire or arching between the distributor cap and rotor will cause that. How long since the cap and rotor were replaced?
wire knot
Re: Irratic timming
Thanks for the replies,
A vacuum test is in the works.
Don, according to the block # , its about right.
I do think the chain cover was replaced.
All the ig parts are new.
This engine runs great up to 4200 rpms,
then when I get into the 4 bbl, it starts to kick out.
It seems like an ignition problem.
I was thinking of replacing the whole distributor.
thanks men, any more ideas?
WK
Re: Irratic timming
Please Explain,..... "it starts to kick out."
If it's breaking down,+ running Rough,.......
I'd be looking at the Fuel Delivery thru the 2ndaries.......
Sounds like it might be going Lean to me..................
wire knot
Re: Irratic timming
bond-o,
breaking down may be a better description.
Just won,t take full throttle.
She isn't runnig rough,except at wot.
180shabah
Re: Irratic timming
Ditto - I would be looking at the fuel side of the equation here.
