Is 40 lbs pressure enough?
Riley1840
Started engine for first time in 40 days. Had muffs on turned on water then started motor [started right up] didn’t see water from Pete hole after 30 seconds so shut down motor. I have 40-45 lbs pressure on hose, did I not wait long enough? Motor has been in vertical position whole time. Reason wanted to run motor was to adjust tach that I just installed.
if that 40 psi comes at 20 GPM, then maybe. if that 40 psi comes at 1 gpm, then no.
jimmbo
How long is that Hose? Was it completely Kink Free?
40 psi, as mentioned above is Meaningless, if the Flow is very low
And now for the Rest of the Story.... Any other work done to the Engine?
Riley1840
Don’t know flow Tate. No work done to engine other then hookup tach. Drag in my curb side trash bin filled up to 8 inch above cavation plate stared engine in less then 30 seconds water was coming out telltale. So I figure I don’t have enough flow. Thanks for replies. On to the next little thing.
Riley1840
Hose is 25 feet no kinks.
jimmbo
In one you say "didn’t see water from Pete hole after 30 seconds "
The next you say "stared engine in less then 30 seconds water was coming out telltale"
Which is it?
Some motors are shy running on a hose.--Too much air in pressurized water is the reason.-------Take boat to launch ramp and test there.
Riley1840
Which is it?
When using hose with muffs no water from telltale. When in trash can with water above cav plate water came out of telltale in less then 30 sec.
MattFL
The hose isn't giving you enough volume of water.
Riley1840
Update finally found a set of muffs that work with my water pressure and volume. Since these split water to both intake sides and have less leakage I can now run motor on hose.
Mc Tool
Ensign
My Honda has the two ports on the side of the gear case but it also has one above the prop in the underside of the cav plate . When on the muffs a lot of water comes out the hole above the prop ..... so much so that the pump wont prime or flow properly ..... I get a dribble at best from the pee hole . I put a bit of duct tape over the hole and it runs great on the muffs . ( I wont tell you that I bought new muffs and a pump impeller , which didnt really help ........already had the duct tape :rolleyes:)
The rubber muffs can get hard with age and wont flex to the shape of the gear case and thusly dont seal well ..... which doesnt help.
Riley1840
I read somewhere that when using muffs I should cover same inlet. Thanks for reminding me to do that.
MattFL
It depends on the motor and how much water your hose flows. My Honda 50 has the same inlet under the antiventilation plate, water pours out there when the muffs are on it but it pumps water fine. I've been flushing it with muffs, without covering that inlet, for 26 years (bought it new in 1999). But yes, the instructions in the manual do say to cover that inlet.
Mc Tool
Ensign
Yep , when I 1st got my onda the muffs worked fine , but we are on rain/ tank water here and I have noticed the water flow is slowly dropping off ( we have been here 10 years ) and now the boat wont flush so I spose Im going to have to find the 🤬filter and clean it :)
