Is 90 HP Motor Enough...
titanxt
Is a 90 horse motor enough on an Alumacraft 175 which is rated for a 150 max?
Thanks!
shark1600
Re: Is 90 HP Motor Enough...
What year Alumacraft 175? i have a 1985 trophy 175 with a 90 horse and it's plenty of motor.
Teamster
It wont be a speed demon but it will be plenty for normal fishing,........
Silvertip
Any boat shoulld have no less than 70% of its maximum rated HP to achieve "minimum" acceptable performance. That does not mean you can't get by with less or that YOU won't be satisfied with performance. But you asked for a recommendation and your boat with a 90 would be a slug in my experience when heavily loaded. A bigger engine loafing is more economical than one that must be run nearly wide open to get on plane, stay on plane, or simply get about with any reasonable speed. Remember, with a bigger engine you can throttle back. With a small engine you can't.
