adrianracer
- Joined
- Aug 12, 2005
- 13
Low hours, fresh water use.<br />Thanks
It is a 3 cyl.Originally posted by ivar:<br /> 2 or 3 cyl? <br />Both should serve you well if properly maintained.
$1200 Canadian or $1000 US!Originally posted by water_surge:<br /> How much $$$?
Can you give me an idea how much more fuel? Is it substantial? This motor has just been fully serviced and has 130 psi compression in all three cylinders and they will give me a 1 yr warrenty on it since I am buying my Bombard boat from them as well.Originally posted by Ben Walker:<br /> Very good engine. Smooth, quiet and poretty much bullet proof. Only negative thing about them is the use more fuel than a 2 cylinder model.<br />Also check the lower unit for water. This motor if stored up right had a tendancy to eat drive shaft seals.
