is a marine carb still required?
As a side question...You have the electric fuel pump controlled by an oil pressure switch so that it doesn't run when the key is on but the engine not running?
Can always count on good answers around here with alot of ASSUMING actually it's hot wired to the battery with bare wireI'm guessing wire nutted to some lamp cord run to the accessory plug on the dash.
