Re: Is accessory circuit an isolated curcuit?
OK, I tried to clarify my original post, but it quickly got long. I explained my concerns at the end of this post, for those that don't want to read it all. Thanks for the help.
Are the house and starting battery negative terminals tied together?
No, there are no wires installed between the house and start negative battery terminals. However, I discovered there is continuity between the two, so something (the hull) has to be tying them together. Since the negative battery cable is grounded to the motor block and the motor is bolted through the aluminum transom, the negative start battery terminal is grounded to the hull. Consequently, there must be a path from the negative house battery terminal to the hull, somewhere on the boat. I was under the impression there shouldn't be one - on purpose, anyway. So, either someone purposely used the hull as a ground (connected the ground wire of an accessory to the hull instead of the 12V negative house circuit (buss bar, whatever), or someone inadvertently connected the metal case of an accessory to the hull (bolted into an aluminum cross member for example), as suggested above. Is there a dual battery switch, ACR or Isolator involved?
No, not yet.
There will be once I finish my wiring (incidently, that's how I discovered my house ground-to-hull condition). There will soon be onboard AC and DC chargers (Minn Kota). They are 100% isolated so one battery will never see another battery. But as it stands today, this cannot be an issue, since I haven't connected any wires, yet. However, I hope to resolve my little issue (if there even is one) before I hook up another 16 wires to the batteries.
Normally, two wires (one black and one red) run from the battery via a circuit breaker at the battery, to the fuse or breaker panel at the helm. From there the circuits split and go to the various loads. Ground wires are not run back to the battery but rather to a ground buss incorporated into the fuse\/breaker panel or as a separate unit. The #8 or #10 black wire carries the ground back to the negative terminal of the battery.
Yeah, that's what I was trying to say in short hand by, "all grounds were directly or indirectly WIRED back to the negative post of the battery (yes, usually through various electrical connections, etc)" It doesn't matter if that battery is the house or the starting battery.
Yes, that's basically my system too, except I have two 10 ga. red wires and three 10 ga. ground wires from/to the house battery. That's not totally unexpected, since I have two livewells and a bilge pump, besides the usual console accessories. All wires (except the battery cables) connect to the house battery terminals. I know terminating wires back to the start battery would also work, but the start battery will only used to start the motor, nothing else. (BTW - There is also an isolated 24V trolling motor w/ 2 batteries at the other end of the boat, but there are no connections between the trolling batteries, the hull, or the other two batteries - I'm positive [or should I say "sure"] - I installed it.)
I'm not sure where each wire from my house battery goes to /returns from. The negatives are ganged together with one ring terminal at the battery. I was hoping I didn't have to cut wires and trace. I know the red wires can only be going to the console (I have power to everything) or the bilge pump (it works) - I suspect one red wire powers the accessories from under the console and the other red wire keeps power to the automatic bilge when everything is turned off, but I haven't verified this. What the odd 3rd black wire is for, remains unknown.
Sorry about the way I quoted above - hope it's still readable and understandable. Thanks for asking for clarificatioins.
So I guess my questions up for discussion are:
Do you think having 12V negative continuity in my hull to my house battery is an indication of a
potential problem (from a corrosion stand point) and I need to investigate further, as indicated below? (If I bought the boat new, I wouldn't be as concerned, but I have no idea who has wired what over the years.)
Or, as GeorgeSalmon implies, should I verify that each and every accessory has a dedicated ground wire (via buss bars, or however) back to the negative house battery post (i.e. ensure someone didn't connect the ground wire of a live well aerator pump directly to the hull with no negative wire connection back to the house battery post (through buss bars, etc)?
Or, should I go further and isolate every accessory case to ensure it's negative connection cannot be inadvertently grounded to the hull (even though it may have a negative wire connecting back to the battery, via buss bars, etc). This step should totally isolate the house battery negative connection from the hull (like I initially thought it would be). This may seem like overkill (overdesign), but it would positively guarantee that there is no way the house battery could possibly contribute to any hull corrosion issues, regardless of how the accessories are hooked up.
My concern: It's probably apparent by now that I suspect I have an electrolysis corrosion issue (with a relatively low hour boat).
I've read on this forum where a boater has had no corrosion problems for years until a technician wires up a radio, or bilge pump, or aerator and suddenly their boat/outdrive begins corroding at an alarming rate. The response has typically been, "take it back and make the technician correct his mistake and wire the new device up
correctly". I have some experience with wiring circuits - and every electrical device on my boat appears to work properly - that's not my issue at hand. However, I've never had an aluminum boat before, so I am unfamiliar with what wiring designs are
correct; and which designs are not
correct for an aluminum boat and, consequently, may have the potential to cause a corrosion issue. So I'm trying to learn what indications to look for, what to do, and what NOT to do.
So far, I'll hook my ammeter up through the house ground and see if I get any current flow, but I should put it on the water to run every circuit, so that may be a while.
Thanks for discussing this issue with me.
Todd
