Re: Is awl grip paint that dangerous???
18rabbit, <br /><br />Paint I used was Interlux Brightside single part. <br />It was reduced with 216 Interux suggested solvent, designed for spraying application. As suggested paint was reduced by 10% of solvant. It was applied on a day when air temperature was about 70 - 75 degrees.<br />All instructions of application were followed as directed. Time allowed between coats - 16 -18 hours.<br />Interlux is not as hard as Awlgrip. I have not used a 2 part Interlux, but pretty sure it will be harder when cured then single part. <br />Interlux single part looks beautiful, my only issue with it was it was not as hard as Awlgrip.<br /> <br />The boat I have now was painted with Awlgrip. I need to repaint repaired secion, not the whole boat. Matching color is a problem. I first tried to mix Interlux white and beige to get to the right color I need. Awlgrip "oyster white" is my color. I mixed and tested for good 3 hours. I thought I came close to matching. paint looked close to what is no the boat, but turned darker once it cured. Then as I was going through paint chips samples from many other companies, I saw Awlgrip. I looked at color names of Awlgrip and saw "oyster white". This is when I remembered the guy who sold me the boat naming the paint. But for some reason I was always sure it was painted with Imron. It was Awlgrip, so that is why I decided to do it with the same paint. <br /><br />Boatman,<br />If I needed to repaint the whole boat I would most likely be doing it with 2 part Interlux.
