Re: is carb kit short a part? 86 johnson 25hp
You will have to order adj. screws as seperate kit from overhaul kit.<br /><br />As for welch plugs, yes they have to be removed to really clean carb well.<br /><br />They are the little **** like plugs that will have a domed apperance. Drive a shap point, nail or mabey grind down philips screw driver to sharp point.<br /><br />Install ones with the dome up and place a small amount of gasket sealer around the edge, place in hole and tap with flat punch to set in place. They have to be tight. But do not completly flatten.<br /><br />Also check to be sure lead shot plugs are tight in their seats as well. If they are lose it will suck air around them. Cause a lean mix and will make for poor idel. Could also damage engine if really bad leak.<br /><br />Welch plugs and lead shots are also seperate kit.<br /><br />More than you ever wanted to hear about uh danged carburator....Huh.<br /><br />Luck to ya!
