Re: Is Compression ok on my Motor?
Where do I start?<br />If the compression was 60 on all cylinders, then yes, it would run lousy. If it ran at all! A good Motor has compression of at least 100 on all cylinders, but an older one may very well operate properly in the 90's, as long as they are within 10% of each other. Regular unleaded fuel is what you should be running! Any outboard oil that has a TCW-3 rating is fine. You would decarb the engine by spraying seafoam or similar product into the carbs while it's running, which will in turn inject it into the cylinders. This will remove deposits from the pistons and rings that may be hampering full compression. It works! Especially on older engines! It is available at many auto parts stores and Marine suppy houses. I'm sure you can find it somewhere and if not, it can be ordered through many catalogs. Good Luck,
