Re: Is fogging a motor a must ?
As F R said Squirting oil in the spark plug holes only protects the cylinders. You are not protecting the lower end - crankshaft and main bearings. You might wanna consider spraying fogging oil in the carb. I have an older boat, A 77 cutlass, 2 Snowmobiles an ATV ,snowblower and a lawnmower, that all receive this routine. In MN every thing has a storage season.
All my stuff still has great compression. Basically, I run engine at high idle, start spraying fogging oil into carb, engine will bog down, sputter and die. If it doesn't stall, have an assistant pull throttle back to slow idle, it will stall out. You don't want it to stall to fast, before internals are thoroughly covered, or have it chug on forever. You will get the feel for it. I like to see the exhaust get smokey. Small outboard would take 3_5 seconds I suppose . My 4.3 V6 in boat is probably closer to 10 secs total. Then I would drain fuel from carb and tank. [ In your case ] Then for added protection, pull spark plug [s ]and do a squirt in cylinder
as you have been doing. Pull the rope a few times w plug out to distribute oil. On your single cyl, I would put the plug back in then [don't hook up wire, don't want it to fire] And slowly pull on starter rope till you feel the pressure building from the piston coming up on its compression stroke. Then STOP, and leave it there for storage. The cylinder is now sealed and closed . I don't know if Sea Foam is a great option. I think its more of a solvent then a lube. I would prob use WD40 before S F. Thats if I couldn't get fogging oil. At a Marina i frequented, they dumped tranny fluid in the carbs for fogging , so IDK, bacon grease would probably work ok !
Then sometimes before I put engine back in service I will take plug [s ] back out and pull rope or crank engine a little bit to blow out any excess oil and to be sure I have no hydro lock issues, in case I squirted to much oil in the cylinders, prob not necessary but playin it safe. Then start it and watch it smoke like a mo fo Then some people clean or replace plugs. I have if I am feeling ambitious ,but they never seem to be fouled really. My 2 Cents.. Any one have any thoughts???
