Is it a 283 or 307 ?
salvageyard saviour
Boat is 1970 Penn Yan
Model TUE 17R / ser. W59674 / 210 hp
Casting number 3862194 which is a 283 block. Last made 1967
Engine code V030I3BB. I can't find the suffix listed anywhere, V indicates Flint plant which started production in 68, which matches the OMC model year.
Could this be a 283 block assembled with the shorter stroke 307 crank? In 68 - 70 ?
440roadrunner
307 is not a 'shorter stroke crank.' I used to know some of the Chev combos back in the day. 302/ (Z28), 327, 350 are all 4" bore blocks. 302 is the old 265/283 stroke crank. 307/ 327 are a bit more stroke, 350 is longer stroke yet. A 307 is essentially a 283 bore block with 327 stroke crank
salvageyard saviour
I had longer typed at first, but my kneepad Clymer book has 283 = 3.25 and 307 = 3.00
Lots of typos in it
the only official source for OMC manuals
BTW, 3.875" bore and 3" stroke is 283, 3.875" bore and 3.25" stroke is 307
move to a 4" bore and 3.25" stroke and you have 327
salvageyard saviour
When I try that website, the book will not go into cart. Same thing happened when I was looking for a 73 OMC manual.
Must be my internet connection
I have better luck on eBay
salvageyard saviour
Manual is on the way.
Still wondering what this is,
Model TUE 17R / 210 hp / 1968
New to me boat. Haven't tried to start it yet. My plan was to install one of 2 fully OMC dressed gen ll 350's I have. One may be a truck block with OMC 245 hp cam & heads. The other is a 165 hp truck engine. They both have all marine gaskets and accessories.
My interest in this 283/307? Is if I can easily get it running and is a healthy motor, I may prefer it for fuel economy.
Also I don't think either 350's will go over 200 hp. One's tired and the other's fresh but a dog.
salvageyard saviour
Still haven't tried to start it, but I know what it is from model number.
TU = 307 😁
KU = 283
Hope I can save it. Seems like a powerful mid size SBC.
