Re: Is it a good idea to run the engine out of fuel
Here's a reason not to do it: "crankcase combustion."
You know how, just as it's running dry the RPM's increase? That's because the mixture gets lean (less gas, more air). When that happens, the combustion slows, and when the intake ports open the incoming charge is ignited and the oil for the crankshaft and crankshaft rings is burned up.
I know lots of folks have done this for years with "no problems." But we wouldn't really *know* if it was contributing to a premature engine failure, would we?
I guess if you only use the motor rarely, you may never get to the point where it fails, and the time you save running it dry instead of draining carbs (or frequent carb rebuilds) is worth it.
But for you, using it every couple weeks, it's a moot point. Just avoid buying more than a couple months' supply of fuel at a time and add a stabilizer.
