Primitive Pete
- Joined
- Jun 29, 2008
- 31
I am carpeting a Jon Boat. Method is to cut plywood to fit decks, floor and sides, coat both sides and ends with 3 coats poly, carpet panel and install in boat. Someone suggested to pad the decks and floor, otherwise the carpeting will wear out fast. If so, what padding would work? Need to glue padding to plywood and glue carpeting to padding. Need glue that will not eat the padding. Any suggestions?
