I went out with my boat and it worked well, no problems. on trying to return my port engine refused to start.
i came home on starboard engine flushed it and paid attention to port engine.
trouble shooting showed water on plugs. suspect manifolds. removed them etc. Takes a while to replace as they have to be imported from Miami.
decide to try to start starboard engine just to keep it active. plan is to change all 4 manifolds. initial try engine seems locked, or battery very dead, removed #1 and #2 plugs they looked ok replaced in engine. second try engine sounded like it turned over with a bit of mechanical noise. not very loud. stopped and removed remaining plugs, #5 plug water wet and dirty. turned over engine using remote starter switch with ignition off and all plugs out. Water seen to come out of #5 cylinder, but small amount, engine turning over freely. removed manifold on that side foamed up cylinder and exhaust port with power foam, left for about 10 mins, While removed other manifold. and then cranked the engine to get foam out. then lubricated exhaust ports, and all cylinders with transmission oil, through plug hole. Cranked engine several times to ensure properly lubricated. all holes spitting out transmission fluid.
is there a real possibility that i may have done major damage to the engine in the initial crank. engine is turning freely with no strange noises.
sounds unlikely to me that the starter, would be strong enough to do mechanical damage, but i know there is a wealth of experience here on this forum. and although i am a pretty competent mechanic, i am not very familiar with V configuration inboard engines, or for that matter inboard gas engines on the whole. But I have been studying on here a lot
I am praying that this was not likely, as getting manifolds to trinidad is enough stress, much more bigger parts.
hoping for some replies
thanks
Pernell
thanks
Pernell
