Is it possible to reverse cams on a Merc 3000 control box?
outboardnut
I've got a Merc 3000 Control box, center console style, 90's model or so.
Trying to rig it up for a Johnnyrude.
I bought and installed universal type cables, merc ends on the control box, Johnson ends on the motor side.
Ran into a snag though.
It's with the throttle cable.
Mercury 3000 wants to pull on the throttle cable to adance the throttle.
1989 40 HP Johnson wants to be pushed for advanced throttle.
Anyone know if these boxes are made to where you can flip the cabs to reverse the operatation of the throttle cable?
outboardnut
Re: Is it possible to reverse cams on a Merc 3000 control box?
Nope as in in can't be done or nope as in nobody knows.
Fuzzytbay
as in can't be done, not atleast without a machine shop making it all up, to fit in the case.
outboardnut
did it, the box has a place to switch the action
Fuzzytbay
That box must be designed for left or right hand controll installations. Normally
you just switch lever sides. Good to know, glad you persevered.
