Is it possible???
absher
Can a 1997 mercury efi 150 be converted to carburated. Will the powerhead work?
oldgradywhite
Re: Is it possible???
Jest wondering why you would want to change from efi to carb?
absher
Ive had some problems in the electrical areas. Gonna keep the efi setup, had to change the ecu, but it should all be good now. I had a xr6 available with a bad block. thought it may be cheaper to just switch it over.
Faztbullet
Yep, all you have to do is use a carbed intake, the bleed lines are capped off on EFI so no drilling , must have all parts are carb engine(linkages & stuff).
