Hi guys, i'm new to this forum but have been watching for a while and learned alot of valuable information. My question for you mechanically inclined boaters is what is causing my motor to not run. The motor is a 1996 Mariner 15hp manual start.
Here is what I know so far:
- the fuel is getting through the carb just as it should and everything looks good on that.
- i'm no mechanic but just in pulling the cord or turning the prop the motor seems to have good compression.
- I replaced the plugs and it still wouldn't fire so I pulled the plugs and did a spark test to which it revealed i have no spark from either of my plugs.
- I checked the kill switch and all seems fine there so I am now stumped as I don't deal with electronics much.
I was told that the switch box is a common problem and that I may have to replace that. Could this be the only possibility or is there something else I can check before ordering a $150 part for a $500 motor?
Any suggestions are greatly appreciated.
