I currently have a 98 Sea Ray Sundancer 290 (10,000 lbs) with a single 454 carb (310 hp model) and a Bravo 3 with a 20p prop. The boat is sluggish to say the least - it hates even having a full tank of gas and is only getting worse with age.
I plane at about 3,700 rpms (85% throttle) and it really likes to run closer to 3,900 at 25mph
I've found a decent deal on a newer 502 mag (415 hp) from 99 (gen 6) and was trying to some opinions on whether the upgrade was worth it... will it have adequate power, can I go up a prop size and increase efficiency/cruising speed? I believe the only modification I will need to make to the boat is adding a new fuel pump correct?
All opinions are welcomed - The reason I'm not really looking for a new boat is I've gotten this one almost perfect in almost every aspect except power (and its paid off).
Thanks!
Thanks!
