MarvinGabriel
- Joined
- May 5, 2020
- 83
OK, so I removed the heads last night, and found the issue that killed the motor. One of the pistons is all tore up! Apparently, something came loose and bounced around inside the cylinder. I suspect a broken ring, (maybe caught on the exhaust port) but haven't had time to remove the powerhead, and tear it down yet. The thing is, the cylinder walls have no ridge at all, don't have any scoring or scuffing (other than the cylinder with the busted up piston.) It also has no vertical play in any of the pistons. I've got experience rebuilding automotive engines (I used to work for a dirt track racing team, and have rebuilt my share of small block chevy engines, and pinto engines. The engine seems, so far, to need to be bored, or re-sleeved, some new pistons/rings and that's about it. At the end of the rebuild, it would still be a 1979 Evinrude, and I can't imagine the parts will be easy to find. Heck, even a partially blown newer motor may be a better deal. I'd still like to hear opinions as to the longer term maintainability of an engine like this.
Thanks!
Thanks!
