Is it worth replacing the powerhead?
displaced47
My 1976 Johnson 70 hp had lousy compression (mid 50's all three) so I pulled the heads and the cylinders look smooth and ok. The local wrecker can get a used powerhead.
What would be included on the replacement? - Like does it have the pistons, crank, cylinders, etc?
Is it worth replacing it or should I do gaskets etc on the old one?
My old thread here http://forums.iboats.com/showthread.php?t=579418 has pictures of the head open.
thanks in advance - any advice would be appreciated.
Lyle29464
Re: Is it worth replacing the powerhead?
I would have to find out why 50# maybe carbon?
could just be carboned up rings.
you have to ask yourself if its worth it. I would ask my wallet. Most of the time it says find an inexpensive solution. you may also want to check craigslist. sometimes you can get a complete motor with a busted lower unit, or other simple problems for dirt cheap.
displaced47
I wish it were that simple for me but unfortunately (in this way only LOL) I live on an island in a relatively remote area and there isn't much for sale within 1000km from here.... i will keep looking though!
Lyle29464
Hi could you please explain what you mean by 50# ?
thanks
An even 50 lbs of compression with the wall looking good I would try to de-carbon the engine. look it over to find the problem.
durban
most likely the rings are stuck in the grooves & not expanding & that's where you lose compression
displaced47
Thanks for clarifying... looking at the cylinders two of them appear quite dark with carbon and the other piston head is white/grey and chalky... what would be involved in de-carboning the engine?
If I put it all back together do you think I would NEED a new gasket or would that be optional? Should the gasket have gasket goo on it?
thanks for your help!
Lyle29464
New gasket, no glue. Go to marine supply and tell them you want to remove carbon. search this site for reinstalling the head.
phillnjack2
Ensign
being as compression was equal i would of got a different compression tester to make sure of the readings.
But to de-carbon it is very simple process and cheap.
you could end up with engine running good for very little money.
phill
displaced47
Thanks all - I will make some further inquiries (read other posts etc) and get back to you... Do you think there is any way to get by without the thermostat? I live in the tropics and there really is no time that the water should be shut off (salt water too).
Also the temp sensor looks rusty and probably dead is it necessary?
cheers
you need a thermostat to regulate water flow. without it, the water is moving too fast to transfer heat and you actually will overheat the motor.
