Last fall, I bought an 89 Glastron 16ft, with an 85hp Force and a 21p prop. After changing plugs and rebuilding the carbs, she would only get to 4k rpms which was good for 21mph. Seems slow, but it was the end of the season, and I was going t rebuild the transom, stringers and floor. Additionally, the 17gal tank was only good for about 3hrs, so I figured while I was at it I'd install a larger tank- went with a 32gal. It's only the wife and I, so I figured the extra 90lbs of fuel wouldn't really affect anything.
Fast-forward through the build, which I pulled about 200lbs of water-logged foam out from under the floor, and she will still only get to 4k RPMs and 21mph. I changed to a 17p prop, and it did bump it up to 4200rpm and 28mph.
I haven't had a chance to really tear into the motor, but last year she was making about 100psi (cold) compression. I'm in the middle of re-sealing my drive-way, but as soon as I'm done (Thursday), I'll pull the boat out and check everything with the motor warm. Looking for ideas from the group here.
Is this thing not making enough power? What speeds should I be seeing on a 16ft boat with this motor? What RPMs should this thing be getting to? There doesn't seem to be any hesitation, and she fires right up every time. Idles fine, even under load and gets on plane fairly quickly without the whale-tail (I removed it thinking that was dragging and slowing her down).
