I'm new to boating, so my apologies for my ignorance. I have an 04 Ebbtide 210 Campione deckboat. It has a Volvo Penta 5.0 Gxi/SX, 270 hp. I believe it weighs in at a little over 3000 pounds and we normally have a pax and fuel load of around 1000 pounds. I bought it with a 3 blade, 21 degree pitch prop that powered the boat to about 40 mph (GPS) and only 4200 rpm. I replaced that with a 4 blade, 14.5 x 17 degree Solas aluminum prop. Now I'm getting the desired 5000 rpm, with a speed of 45 mph.(GPS)
I added SS Smart tabs at the same time, and the holeshot and minimum planing speed is considerably better than with the original prop.
I am disappointed in the top speed (I saw a post from a similar Ebbtide owner that his max speed is mid 50's), and am also surprised by a couple other issues that I find surprising (But remember, I'm new to this boating thing)
First, the boat runs best with the trim fully down in all situations, with a very small speed increase (1 mph maybe), if I trim up just a twitch in some situations. If I do trim up however, a moderate turn will unload the prop and zoom the engine, which I find surprising. It makes me wonder if maybe the trim is not lowering as far as it should. A close look at the mechanism looks like it is lowering fully. My Seloc manual makes no reference to tilt/trim mechanical adjustment.
Secondly, I don't know how to make sure my Smart Tabs are dialed in. I've moved the "force" position up and down the length, and I'm not sure I'm seeing a difference. Should I be sharp enough to detect a difference in hole shot relative to hole positon on the tabs, or should I try to determine the position that equates to max speed?
Should I disconnect the tab and find top speed, then reconnect the tab and position the shock at the final position that still allows that top speed? (But don't they say the tab will actually increase top speed?)
My goal is to try and get the most out of the tab, but not push it to where I've got speed brakes constantly deployed.
Thanks for your insight,
Dan
Dan
