Re: Is my boat trailered correctly?
Talked to the dealer today and he informed me that this trailer was set up specifically for this boat by the Road King trailer manufacturer.
He also said It didn't sit on the guide while in the showroom, so it "must be something I've done".
If this setup was done by the trailer manf. for this boat I would seriously have to question their product. Evidenced by the "It didn't sit like that in the showroon!". "Must have been something you've done". Like what? Use their product?
My point of view is this. Overall the trailer does not look to be too large for the hull. I do not like the design or layout of the bunks though.
Fisrt of all they appear to be 2X8" or 2X10". Why? Second there appears to be only 2 bunks of which they are too long and do not seem to extend forward enough to properly support the hull for the length.
Next, from what I see in the third picture the end of the bunk is already raised as high as it will go. Being as the bolt apears to be located in the top hole! Which also doesn't look to be centered onto the middle of the bunk where it would provide the better strength. Meaning, if they are going to use 2x8" for the bunk then why bolt it 2-3" from the load bearing side?
So my take on this would be, if this trailer was designed for this boat then the manfufacturer didn't do a very good job of it or they just really don't know what they are doing, or it is a generic design for that type of boat and the boat dealer sets it up. Either way I do not like it.
Now my neighbor has a very simular boat and trailer sitting right outside the front of my house right now and I can state there is a world of difference in the "Fit". That trailer also has 4 bunks, dual axles and the bunks are extended mire inches past the transom.
Different designs, different manufacturer, different results.
