I have a 1991 Johnson 30 hp, rope/tiller, 15". I suspect my choke isn't working, but not sure how to test. This motor will not start cold unless I spray a little fuel mix into carb. I have tried starting it with the choke pulled out. I have tried the "pumping choke in and out 3 times" method. When I pump the choke(3 times) the little hose that goes to the top right of carb bulges full of fuel and actually leaks by the zip tie that holds it on.
If I spray some fuel mix in the carb it will start on the first or second pull and run fine afterwards.
Any ideas as to why this would happen?
