Is my engine running too cool?
steviecops
I have a 1980 Johnson 55, and the water coming out of the pee hole is only like warm. This is after the engine has warmed up.<br /><br />Should the water be cool? And if not, what might be the problem?<br /><br />Thanks<br />Steve
OBJ
Re: Is my engine running too cool?
Hi Steve....How are things in the mother land? The Colonies are doing well. Now to the question.<br /><br />Luke warm is about good as it's going to get since the water is almost directly from the water pump. Just be concerned with a good stream from the pee hole and the temp on the flat area in back of the head.
crazy charlie
Warm water coming out is ok.Take off the cover and place your hand around each head.Are they the same???are they hot????are they warm???They should be the same temp and only warm.Not burning hot.Installing a gage is cheap and easy and well worth it.Charlie
ob
Telltale water on that engine should be as you describe.Warm.If you can rest your hand on the head cover for several seconds after engine is warmed up without getting burned ,it is likely running fine as well.However,the t/stat on your engine should be replaced at least every other year.This will prevent it from becoming sticky and causing you some real problems down the road.
ob
Dang,Looks like we were all on the same wavelenghth. ;)
steviecops
God I love this site !<br /><br />I just posted my question, and have had 4 really good replies already. Thank you all very much.<br /><br />Outboard Jim, Things over here are not too bad at present, but could be better. Until we finally get rid of bLiar, I'll keep dreaming of living in the States ;o)<br /><br />Thanks again for the advice.<br />Steve
