jonny rotten
- Joined
- Jan 8, 2012
- 380
1990 Mercruiser 4.3 alpha one
Forward shifts fine, the issue below is for reverse
The slide bolt on the lower shifter bar is as high as it goes.
If I pull the cotter pin and rotate the barrel almost to the end and slide the barrel into the housing it shifts fine for testing...but the barrel wont slide in all the way inside the barrel housing because the crimped nut on the cable hits the barrel housing. If I rotate the barrel back to where the cotter pin fits it stalls.
Does this mean my cable its stretched to the max and need replacing.....it worked fine when I put it away last year but has needed adjusting in the past.
I watched the YouTube videos on adjusting and the measurements I'm wondering if this is a sure sign of replacement being its raised to the top of the adjustment and bottomed out on the barrel...Thanks
