Is my Mercruiser fuel injected or carb?
CapriBX
I’m struggling to figure it out. There’s no serial number.
CapriBX
You know what, now that I’m looking at the photos, I think it’s a carb. There’s one fuel line going in the front and no fuel rails in sight. I don’t see a fuel return line either. I may be mistaken.
Lou C
Looks like a Mercarb (modified Rochester 2bbl).
Scott06
Yeah you’re right there. Is a conversion kit worth the money?
No not to TBI but you will see some gain if you swap out the 2 bbl for a 4 bbl . would need an intake manifold too . I did that with my 5.0 runs very well and has great midrange throttle response. The eddelbrock 1409 is pretty good right out of the box on a 5.0
Lou C
Agreed I’d always want a 4bbl carb in a marine application on a V6 or V8. They are a bit more complex to set up & rebuild than a 2 bbl but I feel it’s worth it.
CapriBX
What manifold did you use?
jimmbo
The Holley 500cfm 2bbl is the Perfect size for a 5 liter, spinning up to 5000rpm
jimmbo
Would a 4bbl not be better?
If a 2bbl can provide all the Airflow required, a properly set up 4 bbl will not provide more. The 5 liter spinning at 5000 rpm with a Volumetric Efficiency of 75-80% needs about 350cfm, so like I said, the 2bbl Holley is very close to that. However a small 4bbl, around 400cfm will have smaller bores, and that can result in better throttle response, and better atomization of the fuel at low engine speeds and reduce the chance of leaning out(flat spots) as the throttle is opened
CapriBX
CapriBX
So, the 4 barrel would be better? I’m getting confused.
jimmbo
If a 2bbl can provide all the Airflow required, a properly set up 4 bbl will not provide more. The 5 liter spinning at 5000 rpm with a Volumetric Efficiency of 75-80% needs about 350cfm, so like I said, the 2bbl Holley is very close to that. However a small 4bbl, around 400cfm will have smaller bores, and that can result in better throttle response, and better atomization of the fuel at low engine speeds and reduce the chance of leaning out(flat spots) as the throttle is opened. Also, you should never be able to "feel" the Secondaries open on a 4bbl. If you do "feel" a surge, what you are experiencing is a Lean-out, followed by the Main Circuit delivering fuel, and the engine catching
CapriBX
Alright, so the Holley would be more than enough CFM for the 5.0. Would I see significant performance? Or is it not worth the time and money?
