1989 Evinrude 60 hp. Hit something with the prop in the Charleston Harbor today. I can go forward and reverse slowly. If I add throtal the motor has an increase in RPMs but the boat will not, it seems to slow. SO forward and reverse work in lower speeds, I was going agaist the tide....basicaly trolling, and higher power I'm out of luck.
The prop has a ding on it...
Is it a clutch problem? teeth on the prop? damaged gears?
HELP! I need to Boat!
