Is my prop hub spun? Motor spins out of control!
Merc90HPnewbie
Ok here's a synopsis: 1985 16 ft fiberglas runabout with a 1985 90 HP Mercury straight 6.<br /><br />Everything was fine last time out. Boat went up to about 40 MPH. This time out whenever I tried to go up over 8 MPH or so, the motor RPM's went nuts...<br /><br />I was fine at low speeds but couldn't get up on plane or go over 8 MPH.... <br /><br />I tooled around at low speed and looked at the motor, water output was fine and not too hot to touch. hummmmmmmmm (throttle up) and then VMUHHHHHHHHHHHHHHHH.<br /><br />What the heck?<br /><br />The only thing I can think of (mind you my boating experience consists of reading The Idiot's Guide to Boating) is that I spun the prop hub out and it won't grab over a certain speed.<br /><br />I have another prop but I'm kind of afraid to go out again until I know what's wrong.<br /><br />*Nothing* happened to the prop though... I didn't hit anything. There was a very small amount of fishing wire on the prop (not back by the seals). It was not wrapped around the prop or anything, I think I just dragged it out when I put the boat back on the trailer. And the prop didn't look any worse than when I put in.<br /><br />I didn't floor it or anything to apply lots of torque to the prop. <br /><br />Any ideas??<br /><br />Thanks!
jim phillips
Re: Is my prop hub spun? Motor spins out of control!
Sounds like you spun the prop. Change it and give it a try.
Merc90HPnewbie
Thanks Lucky Jim. What causes them to spin out like that? I have a spare prop but is hub replacement something I could do? I don't have a hydraulic press or anything...
jim phillips
Find a prop shop and get it reworked I dont think it is a do it your self repair
greasemonkeyozi
Props just sheer on occasion, like if its old or something. If my memory serves me correctly, merc props have a rubber bushing as a sheer mechinism. Rubber dryrotts, as ya know. In time with a little dryrott, and a little bit of torque will sheer a prop. <br />S@?* happens.
