I'm fixing the water pump on my outboard after making the newbie mistake of dry running the motor.
I'm located in Australia, and for those that arn't aware the replacement parts are nearly 4 times more expensive here compared to there prices in the USA (I'm actually currently looking into purchasing from the USA and having it posted, as it would seem this will still be cheaper) - for this reason I'd like to replace as little as possible, but don't want to stinge out and not replace something that I should have.
I've removed the lower unit, and pulled the Upper Housing off the water pump, and removed the impeller.
It looks to me like the top hole in the Upper Housing for the driveshaft has sustained some damage (the driveshaft is fine). Pictures:
