Is Pennzoil marine high viscosity gear lube ok?
rk2fish
I went to the local Walmart to get some gear lube for my 1994 88hp johnson and all they had <br />was penzoil gear lube. Will this work ok? My local marine shop was closed on saturday or I would<br />of bought the right stuff. I'll definitely change if it is going to fry my lower unit. Thanks.
ob
Re: Is Pennzoil marine high viscosity gear lube ok?
rk2fish,Penzoil Hi-Vis is what I have used to service the lower unit on my 95 70 hp the last 3 changes.It works well.I bought the ones in the 10 oz.squeeze tube.
